Originally Posted By 67SATisfaction
Originally Posted By ruderunner
Rotor run-out can also knock the pads back
.. but wouldn't you feel the pulsation pretty clearly in your feet, via the pedal? ..and he checked the runout..
not that I have an answer.. unusual for a disc brake setup... if this is behaving different than last year when you had drums, I'd focus on the new disc setup you changed.
- Art
Pad knockback due to bearing compliance when cornering isn't all that uncommon for aftermarket setups, and will not provide you with a pulsation.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
