Just a pair of homemade welded in subframe connectors.
I believe I mentioned it some years ago in some topics, but I can't help but wonder if just simply welding the entire K-member onto the frame rails would be a much better idea, just like C-bodies that have a one-piece front frame).
With use a some proper gusseting near the mountpoints I think the entire front end will be unsurpassed in strength.
