I use a vacuum pump and a air flow meter to measure leakage. The biggest that I have found are the crankshaft seals. In fact if you pressurize the engine with a smoke machine the rear seal doesn't seem to leak, pull 10 inches of vacuum and it's a different story.
Joe
Without Data, you’re just another guy with an opinion.
