Spent part of the day setting up a car very close to yours weight and front suspension wise using 8" 350 springs. I expect the 375s will be way heavy for your situation. 350s are compressed very little at the shock length we are using, but should be fine on this car at the power level he has.
If the results don't match the theory, change the theory.
