As far as I know, that is your best option. You do not want to go with the Autometer tach adapter 9117, as it requires that you splice into all eight of your coil pack leads.
I am running the dakota digital SGI-8E and the MSD tach signal GMR pickup PART# 8918 to supply a tachometer signal to a Aeromotive billet fuel pump controller.
