On my E I cleaned out the trunk extensions as best possible. Mechanical means like stiff wire and shop vac. Then high pressure water. Then let it dry thoroughly and applied Eastwood waxy rust proof from the inside until it dripped out the water drains. This stuff will seal small gaps (eg. 1/16"). Bigger gaps will need additional help I guess.
