P4529117 is a newer number for P4532060. Same manifold, different part number. I found a pic of the P4532061 and it looks identical to the other 2. These are nothing more than aluminum versions of the factory cast iron HP manifolds.
I used to have the RB version on a 440 years ago. It's exactly the same as the cast iron piece...weight savings is the only advantage.
