That's it, about a healthy 1/4" gap from the rim bead edge, that's the ugliness of factory 14" trim rings road or rallye.... When I ran 14"s I ran an aftermarket trim ring so that it contacted the rim's bead/edge
If your going OEM that's what you got to live with
