Anyone using Comp cam # CL20-224-4 in their small block? If so, what is your vehicle usage (street/strip)? 727 with stock torque converter? Rear axle gear ratio?
Also looking at CL-222-4 and CL-223-4.
I'm considering to run a stock 340 4-barrel torque converter and a 3.55 gear. Exhaust manifolds are preferred.
