Nice performance numbers, not sure id be comfortable running it on pump gas any higher then your timing is set. But I know you know that as well. Did you do a cranking comp test? My calcs on your DCR is at 9.40 Typically with a 9.4 comp, cranking psi would be around 140/150.
