In a car without a funny car cage, we fab a U shaped mount, attached to the center of the main hoop, and extending forward to mount the lever horizontally, right where the driver wants it, with an attachment for the cable. The lever is mounted where the driver can pretty much swipe it with his hand without having to look for it and the whole affair is kept up tight to the ceiling so the guy's not bashing his head against it. We use Morse cables and proper mounting hardware. Not the cheap stuff that comes with the kits.
