Originally Posted By 6PKRTSE
If I remember correctly when we cut the M.S. 12 point cage out of my buddies G Body (GM) & did the 25.5 cert C.M. cage upgrade when all said & done it was 25-28 lbs lighter than the old cage.
So, how many more feet of CM tube did you use over the 10 point?
