I used one of those Isky grinds on a solid roller cam in the first motor I built for a customer, that cam is a really old school design
![work work](/ubbthreads/images/graemlins/custom/work.gif)
I didn't worry about the manifold vacuum and I didn't degree it, I lined up the dots and let the customer have the motor
![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
it was a dead dog below 3000 RPM and then it came on like it had a NOS kit on it, I'm going to say it was probably retarded some
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
On your deal make sure and degree that rascal in
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
Do you know what lobe separation angle it is ground on? If it is ground on a 108 or 106 LSA try installing it 4 to 6 degrees advance, put the intake lobe in at max lift at 101 to 104 degrees after top dead center, that will help the bottom end a bunch
Please let us know what you find out
I ended up using a bunch of different Isky grinds after that one in both street and strip and drag race only cars, all of them where good as long as I degree them in properly
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
The best solid flat tappet grind was the old 616/590 dual patter cam, it was for drag racing only, the LSA was 104
![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
It work really good on the street also with a decent converter installed form 100 to 104
To bad they quit listing it in their catalog
![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
It can be bought now as a special grind but other company have better cams now
