Originally Posted By Alaskan_TA
The under hood skins have holes for the pins, so the hoods themselves should be measured.
Mounting brackets / pins can be bent, tweaked etc. but the pin holes should be centered via the larger under skin holes in the hoods.
I easily could have given you an under hood skin education Jim, I'm so so sorry for giving you exactly what you asked for.
