Take the washer out. you do not want less flow, you want more. Putting a washer in the coolant flow is like putting a piece of cardboard in front of the radiator with a 6" hole cut in it.
But a thermostat reduces the flow as well
Yes they do, but not down to a 5/8ths washer hole restriction.
