Originally Posted By 6PakBee
Originally Posted By Silver70
All you need to use the vin of an existing car is to use the a pillars and cowl of an original... not sure the exact dimension, but is a legal way to do it.
That's basically what Fantomworks did to that '57 Chevy replacement body. I can't remember the details exactly but as I remember they just used the pillar with the existing VIN.
A pillars and upper cowl section, the whole section has to be at least 22" in overall width minimum as per Federal guidelines when transplanting your donor VIN into the "replacement body"...
