yes it has subframe connectors. Im Sure its just because I have everything out of it and theres not much supporting it .Ive got it all supported and level so ill weld in some bracing for the package tray and get the tubbs in and welded in and then the bars. I'm pretty sure it will be fine after that . Thanks
