Got a suggestion for something better to loosen that check needle?
PB Blaster is pretty aggressive. Or some kind of mild acid, like the stuff you clean nasty aluminum with to weld it. Blow gun from the metering block side of the carb body. Just be careful where it's aimed or cover the top with a towel.
If the results don't match the theory, change the theory.
