Put the rear axle on top of the springs will give you about 5" drop. You will have enough room for travel up and down for the axle. Change your shocks to the right size needed. I change the shock angle for racing. I still run the rear stock springs. Any question send me PM> The last picture was taken when I first lowered the rear, before the bed was taken off to modify the frame for a fuel cell and paint.
