If your angle finder is facing towards the back on the trans output shaft, and it is facing forward on the front of the pinion, you may want to check your numbers again. To get accurate numbers, the angle finder needs to be facing the same direction on both ends, or your measuring one of your angles from the wrong direction. Gene
