One area to check is the bracket on the bottom of the side glass that the window regulator arm rolls in. There should be a soft liner in the groove to the glass, they wear out and glad touches metal and they rattle. Drivers door goes first. You can make your own to fix this rattle spot. Remove the blue rivet to take the bracket off the glass and install a new liner.
