I bought a couple big casters like those, bolted them up to two 2x4's stacked on top of each other, then drilled a hole on each end and bolted them onto the rear k-frame bolts. However my car being a 74 has an extra set of k-frame bolts more rearward and lower, roughly even with the firewall so it was easy. I imagine you will have to do a little extra cobbling but if you can find somewhere further back on the frame rails it should be doable.
