With vacuum unplugged from distributor, engine idles down correctly. I also checked for vacuum leaks and didn't find any.
that tells me that it is dist related, either a vac leak as of yet undiscovered or weights hanging up. I'm assuming you've vacuum pumped the can/hose & I would go inside the dist & go over it.
