Building my 440 and since it's been awhile since I've put an engine together and I've been searching about where to clock piston rings without any luck. I looked in my piston ring instructions and there isn't any info there either. From what I remember you don't want ring gap on the thrust side of the piston but I can't remember for certain. If anyone has a diagram or can lead me in the right direction I would appreciate it! Thanks!
