Originally Posted By Dave Hall
This is the ultimate green goop!
My bracket car came with the Redline lightweight shock proof gear oil in it, it had a blown B1 motor on methanol in the car with 5:87 pro gears that had gone 7.84 at above 186 MPH work Those gears look excellent so I bough several gallons of it to use with the used pickup Dana Corp 4:56 street gears I put in it up No noise or problems so far with my little 700 HP bracket motor shruggy
Redline sells several different versions, weights, of their Shock Proof gear oil, good stuff up scope
