Pull the inner panel (splashield)
You can pop the spring off with a large screwdriver BUT it's not necessary (it sometimes helps relax the hinges allowing them pull off the pins easier.
Mask off the inner fender, hinge area
Cut off the retaining rings
Reach in with a long screwdriver and gently pry the hinges off the pins
It WILL take some time and finess but you will get them off without pulling the fender or door.
It is a frustrating job but alot easier them pulling sheetmetal.
