What I have done is replace the spray cap on the rustoleum 7220 texture black with the cap from a Sem paint cap that has a wider pattern . It was much easier to get a good wide pattern on the flat areas of the dash. If you really want to get a good pattern remove the paint from the can and put it in a cheap Harbor freight gun .
