Re: 360, A/C, Weiand intake,Comp bolt hitting thermostat housing
[Re: 4406bbl]
#2450481
02/12/18 02:17 AM
02/12/18 02:17 AM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Paddle faster! I hear banjo music!
Ya, grind one flat of the nut at a 45 and call it a day. This. And as a side note why are you using RTV sealer with a gasket? RTV is meant to be the gasket, adding it to a gasket just makes the whole thing sloppy. I never use any sealant on gaskets except in the corners of some applications.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Entire Thread
grancuda
02/11/18 06:11 PM
grancuda
02/11/18 06:13 PM
mopars4ever
02/11/18 06:31 PM
Supercuda
02/11/18 06:45 PM
340Cuda
02/11/18 06:44 PM
4406bbl
02/11/18 08:53 PM
Guitar Jones
02/12/18 06:17 AM
Porter67
02/12/18 08:52 AM
Supercuda
02/12/18 04:13 PM
Eggman
02/12/18 01:29 PM
PurpleBeeper
02/12/18 08:07 PM
mopars4ever
02/14/18 02:02 AM
