Is there a limit to how many amps you can run with stock dash wiring harness? Do you need a different voltage regulator?
Yes. Its only 40 or 60amps.
...i have my alt wired right to the battery so it bi-passes the amp gauge. Even with the stock alt this helped things alot.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
