Originally Posted By AARCONV
Depends on handful of miles..i would run it first..before spending money on it..but I would do the water pump...
Supposedly it has like 1500 on it. I pulled the valve cover and it's spotless. Why the water pump? I am going to dress it as a mid 70s version, so AFAIK the water pump and timing cover should be the same - I was going to leave it alone. Motor is non-AC and I am using it in an AC car though, so maybe the pump should be changed.
