I've had another one of my complicated and expensive ideas that I think could be really cool. I looked up the dimensions for both the 1970 Challenger and the 2016 Camaro, and they're actually surprisingly close. Very close in wheelbase length and only 3" difference in overall length and height, 1" difference in width. Would it be remotely possible to put the Camaro chassis into the Challenger? I only ask because the modern Camaro handles extremely well, but I'm not sure if it would end up being better, worse, or not worth whatever advantage would be gained versus the aftermarket options already out there like the Hotchkiss TVS, or the AlterKtion and Street Lynx kits? If I did this would I have to switch to a gen 3 Hemi or could I manage to keep the big block?
The easier approach would be to just re-skin the Camaro with AMD/Goodmark/dynacorn Challenger repro sheetmetal, this way you retain all the engineered value put into the Camaro chassis/driveline, rather than frankensteining both cars, it would be a less daunting project that way
