Removing a lower control arm bushing outer shell made easy, if you run a 1-3/8 tap into the shell of the bushing after you press out the pin and remove the rubber you can run the tap into the control arm bushing outer shell and press the tap and shell out just like you did the pin. Thanks to the For A bodies only member who shared this trick, and my friend George who told me.
UCUDANT
That would be me.
Glad that "trick" worked out for you.
I have heard that lots of enthusiasts have benefited by doing it that way, even though there is a welding in a washer method, too.
Jim V.
hemi71x
