Most of the smaller bore aluminum chrysler based master cylinders have no bias. For example, pre abs Caravans had cross braking hydraulic systems. Each port on the master cylinder controled one front brake, and the opposite rear brake.
This is not to say they cannot be used on a front to rear split system, but understand that there is no bias built into MOST of the non truck masters.
"use it 'till it breaks, replace as needed"
