Wedge, i have the ez 295's and run a 45 thou head gasket. The block has been decked 2x and i run the smith bros ball/cup. the ball is a 5/32 which was real important in measuring for the overall length. I ended up with a 9.690 overall length. i don't think the comp pushrod length checker has a 5/32 ball on the end Another point, if you are running the supplied rocker assembly from Indy their instructions differ from the typical 2 thread count on the adjuster.
Oh yeah, solid roller with the comp 829 lifters!!
Let us know what you end up with.
did you get your measurements measuring with the rocker adjuster with no threads showing ???
Mopar Performance
