Not exactly sure what you are asking but I suspect you mean how much air space above the oil line to the lowest point of the crank when the engine is running? What is not shown in the picture is the deflector/scraper that attaches to the passenger side of the skirting. This will have a five stage pump so each of the depressions in the lower pan will have a scavenge line.
