Thanks for the answers. Here more info:
318ci ~300hp on it. 4.88 gears. 3speed column shift.3300lbs Car. 28x9x15 old slick Hoosiers. E100 fuel. Ceramic clutch.
Launching on 3000rpm. Have option to enable two step of needed. Prepped track.
Next race will be different as I installed some progressive dry nitrous.150 shot going from 3000 50% - 5000 100%.
But still want to hear your opinion on the launch. Thanks.
Use the two step. You need to over rev the engine for the ROm drop on the three speed.
What clutch and what shocks?
