0.0632683" is (1) degree. measure out a strip of paper for how many degrees you need. IE 2&1/4" (2.246") is 35.5 degrees. How hot is "hot" Confirmed with a good mech gauge? is this a new ring breakin? I'd think 30 deg (1.898") at 2000 RPM would be enough to keep it from overheating from retarded timing.
