Since mine is a foot brake car it leaves at low rpm, 2900-3100. It takes just over 1 second before it's up on the conveter flash, (6000). I've often wondered how to improve that time frame. If you're on the brake at higher RPM that time is less. Even though the big tubes show power on the dyno it may not translate to acceleration through the range.
Doug
