rrunner, The CRC cosmoline I used is really thick. You would never get it to spray out of any spray can tip. I can't even use it in the winter unless I warm it up to 120 degrees. I'll say that the spray can version looks pretty good, right color hue and all. Great for the do-it-your-selfer.
Yes, It is thiner, but with a few coats it's good to go and think I could get the hung/run look. It's just a thined out cosmoline, the smell tells it all . Don't know how this spray would work in the cold as we really don't see cold here.
