Possible clock spring? Does the lite in dash stay on?
dash light might come on for a while--then goes out--it is hit or miss if it will stay on or not but only stays on a while then pops out/off
Tried brake light switch --Nope--replaced switch in steering wheel --Not that either
Horn and all other stuff on steering wheel works so could it still be clock spring?
What about the TIPM? Do I just need a hard reset--like attach the battery cables together for an hour or so to reset--does that work will it help/ can it hurt anything? Wiggled all the fuses etc no change
