If you want to find one you can rebuild yourself and run, find one of the 6000 series, ie the first number is a 6, the other 3 are anything else. The 9000 series are the smogger carbs, which would need some rejetting and other mods before being good to use.
The Vaanth Thermoquad Guide has all the numbers you need to see:
http://members.shaw.ca/crussel/thermoquad/tqguide.html
Not all 9000 series carbs are "smogger carbs". I ran a #9023 on my built 340. I would recommend using a 72-74 TQ carb. A SB or BB TQ carb will work well on a 340. Just make sure it's jetted right for your application and has a good set of performance metering rods like 1966's.
You can get other TQ's to work well but someone like Demonsizzler would probably have to modify or tweak it.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
