Although a bit more rare a cracked piston skirt can sound like a rod or wrist pin.
But as everyone has said, dont run it anymore.
Try a socket/breaker bar on the crank bolt and move back and forth gently just a bump, and see if you hear a thunking noise as well, you might here somthing is already loose.
