If they were the same they would have the same part number.
It appears you want a resto look and that precludes using anything other than the original setup. If close enough would work, then I refer you back to the link I posted.
The difference is length.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
