The check engine light doesn't come on until after I crank it a whole bunch. Dunno if on-off of the ignition switch helps or not, but eventually the light lights up and flickers with the rapidly actuating relay. I hold the pedal down about 1/2, keep cranking, and eventually it starts, sounds like it's firing on 1 cylinder, and during each firing event, the check engine light goes on and off. Eventually it smooths out, the light stays off, and it runs fine, although it idles a little low. Craziest crap I've ever seen. Sounds like an ECM?
Do you angle park in a parallel universe?
NHRA Division 3 Announcer
Great Lakes Dragaway
DJ-Saturday Morning Cartunes/The Gearhead Show
6-9a.m. Saturday mornings
WMSE Milwaukee 91.7fm
www.wmse.org
