I guess I look at it as...... How many different intakes do you need?
If you're running MW heads, I would just assume you're doing that because you're trying to make some power....... And the Indy intakes are fine for that.
If you're looking for a kinder gentler low deck stroker, run std port heads, and then there are more choices suitable for lower power level builds.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
