In ootb form, IMO the TF240 is the clear choice for builds where a std port opening is preferred and you’re looking for over like 550hp.
As has been discussed before, the primary determining factor for that at this point is the quality, flow..........and price.
If the heads all cost the same, the choice wouldn’t be as clear.........but they don’t, and it’s pretty difficult to approach the potential of the TF head for equivalent $$$.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
