Looking at your good picture of the governor support... its pretty evident that something came thru the main lube feed to the output shaft based on the metal displacement from that hole towards the small feed that lubs the rear drum. That would seem to indicate something comming from the cooler area.
my thought's exactly, what ever it was I seriously doubt it was from the trans it self, converter get's my vote.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
