The stock gauge in my 70 Charger scales up to 80 psi. If I install a sending unit with the 100 stamped on the side, will my gauge still be fairly accurate? I think that the 100 on the sender indicates it should be used with a gauge with max scale of 100.
Thoughts?
68 Charger
70 Cuda
