Originally Posted By Cab_Burge
Originally Posted By markz528
Thanks for all the replies. Since those are stock rods they owe me nothing and they have not had an easy life.
tsk You have learned a valuable life lesson from this ,huh whistling
Buynig or choosing cheap parts in a non stock Hi Po motor will buy you future problems, usually shruggy
Good luck from now on thumbs
You need to understand that when this motor was originally put together cheap aftermarket rods and cranks did not exist. It was a great motor. When we detuned it the crank went THUD when put on the ground so it got replaced. Other than that was a great motor for a very long time.
The replacement motor is a 2001 megablock with Eagle parts. The new build is a new "The Block" with all Molnar internals. This is just a low power spare motor now.
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
