Check out your local car parts swaps. I usually found carbs for the 5-15 dollar range for parts. Is yours stripped out where the needle and seat threads into? If so, the cause is using a non Holley needle and seat which uses a big brass nut to lock things down. You get these in parts store aftermarket carb kits. The thread pitch is off 1-2 threads from the correct one and will strip out the bowls. Gots to use oe Holley or one of the better companies like Quik Fuel etc to get correct stuff.
Carl Kessel
